Hello,
I need a bit of guidance. I am converting my old Anilam 3 axis CNC Bridgeport over to a modern control system. I have Mach3, Viper drives for the DC servo motors. I bought the KFlop after some research revealed that Mach would not work well with the existing glass scale when I would use the mill in manual mode.
My questions are;
1) Do I need a break out board and what is recommended? I have a CNC4PC C11 and a C11T.
2) Can I place the KFlop and B Board in the same enclosure as the power supply and servo drives?
The original Anilam enclosure that held the power supply and cards would be my first choice for an enclosure. I would like to keep the original PS and reuse the cables and connectors to the servo motors. I plan on routing a separate isolated and grounded cable from the motors to the viper drives. The enclosure has separate cable and connectors for the glass scales which i would rout to the Kflop.
